Click or drag to resize
GTPUMasterDialogActionItemEnabled Property
Gets or sets a value indicating whether the control will have an Action item in the command bar.
Namespace:  ABB.Robotics.Tps.Windows.Forms
Assembly:  ABB.Robotics.GTPU.Windows.Forms (in ABB.Robotics.GTPU.Windows.Forms.dll) Version: 6.5.129.0
Syntax
C#
protected bool ActionItemEnabled { get; set; }
Property Value
Type: Boolean
true if the control will have a Action item; otherwise false. the default value is false.
Remarks
The Action Item will be shown if this property is set to true and the Menu property is not null. The Action item is located in the right side of the command bar following the GTPU guidelines. The text of the Action item could be set by the property ActionItem. The default text is Cancel and its localized. In order to be notified whenever the Cancel item is pressed, inheritors must override the method ActionItem_Click(Object, EventArgs).
See Also
