Click or drag to resize
ListViewItem Properties
The ListViewItem type exposes the following members.
Properties
  NameDescription
Public propertyBounds
Gets the bounding rectangle of the item, including subitems.
Protected propertyCanRaiseEvents
Gets a value indicating whether the component can raise an event.
(Inherited from Component.)
Public propertyCheckBoxVisible
If CheckBoxes are enabled, specific items can have their checkboxes removed.
Public propertyChecked
Gets or sets a value indicating whether the item is checked.
Public propertyContainer
Gets the IContainer that contains the Component.
Protected propertyDesignMode
Gets a value that indicates whether the Component is currently in design mode.
Public propertyEnabled
Gets or sets a value indicating whether the item is enabled.
Protected propertyEvents
Gets the list of event handlers that are attached to this Component.
Public propertyImageIndex
Gets or sets the index of the image that is displayed for the item.
Public propertyImageList
Gets the ImageList that contains the image displayed with the item.
Public propertyIndex
Gets the zero-based index of the item within the list view control.
Public propertyItemName
Gets or sets the name of the component.
Public propertyListView
Gets the ListViewListView control that contains the item.
Public propertySelected
Gets or sets a value indicating whether the item is selected.
Public propertySite
Gets or sets the ISite of the Component.
Public propertySubItems
Gets a collection containing all subitems of the item.
Public propertyTag
Gets or sets the object that contains data about the control.
Public propertyText
Gets or sets the text of the item.
Top
See Also
