Click or drag to resize
ListViewItemEnabled Property
Gets or sets a value indicating whether the item is enabled.
Namespace:  ABB.Robotics.Tps.Windows.Forms
Assembly:  ABB.Robotics.Tps.Windows.Forms (in ABB.Robotics.Tps.Windows.Forms.dll) Version: 6.5.129.0
Syntax
C#
public bool Enabled { get; set; }
Property Value
Type: Boolean
true if the item is enabled; otherwise, false. The default is true.
See Also
