ITpsViewSetupInstall Method |
Install will be called by TAF when the TpsView is created
Namespace:
ABB.Robotics.Tps.Taf
Assembly:
ABB.Robotics.Tps.Taf (in ABB.Robotics.Tps.Taf.dll) Version: 6.5.129.0
Syntaxbool Install(
Object sender,
Object data
Parameters
- sender
- Type: SystemObject
An interface reference to TAF site services. - data
Initial data if provided.
Return Value
Type:
Boolean
True if the method is executed else false.
Depends on the called method implementation.
See Also
