SDKViewWrapperInitNewContext Method |
This method is fired when an UIShow instruction is executed and the InitCmd parameter is set to a value.
Namespace:
ABB.Robotics.Tps.SDK.Base
Assembly:
ABB.Robotics.Tps.SDK.Base (in ABB.Robotics.Tps.SDK.Base.dll) Version: 6.5.129.0
Syntaxpublic void InitNewContext(
Object context
Parameters
- context
- Type: SystemObject
An object containing the new context.
Implements
ITacContext.InitNewContext(Object)
See Also
