ABB.Robotics.Tps.SDK.Base Namespace |
| Class | Description | |
| GtpuAsmIdAttribute |
This Attribute Class is used by the SDK Proxy View. The Attribute
holds a Unique Identification string that identifies the SDK Stub View that
correspond to the SDK Proxy
| SDKViewWrapper |
This UI class encapsulates the functionality of loading a customized UI in a SDK Domain.
