GtpuAsmIdAttribute Class |
Namespace: ABB.Robotics.Tps.SDK.Base
public class GtpuAsmIdAttribute : Attribute
The GtpuAsmIdAttribute type exposes the following members.
| Name | Description | |
| GtpuAsmIdAttribute |
Creates a new instance of the GtpuAsmIdAttribute
| TypeId | When implemented in a derived class, gets a unique identifier for this Attribute. (Inherited from Attribute.) | |
| UID |
Gets the Unique Identification String.
| Equals | Returns a value that indicates whether this instance is equal to a specified object. (Inherited from Attribute.) | |
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| GetHashCode | Returns the hash code for this instance. (Inherited from Attribute.) | |
| IsDefaultAttribute | When overridden in a derived class, indicates whether the value of this instance is the default value for the derived class. (Inherited from Attribute.) | |
| Match | When overridden in a derived class, returns a value that indicates whether this instance equals a specified object. (Inherited from Attribute.) | |
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
