Click or drag to resize
ExceptionHandlerTraceHandledSystemExceptions Method (String, String, Exception, String)
When a System.Exception have to be hidden we should call this function so that we can at least log the exception information. NOTE: This function should not be used unless we really really really have to. Every exception should be taken care of instead.
Namespace:  ABB.Robotics.Tps.Resources
Assembly:  ABB.Robotics.Tps.Resources (in ABB.Robotics.Tps.Resources.dll) Version: 6.5.129.0
Syntax
C#
public static void TraceHandledSystemExceptions(
	string obj,
	string method,
	Exception e,
	string additionInfo
Parameters
obj
Type: SystemString
Calling object name.
method
Type: SystemString
Calling method name.
e
Type: SystemException
Original exception.
additionInfo
Type: SystemString
If you want to add more info.
See Also
