ExceptionHandlerTraceHandledSystemExceptions Method (String, String, Exception) |
When a System.Exception have to be hidden we should call this function so that
we can at least log the exception information.
NOTE: This function should not be used unless we really, really have to.
Every exception should be taken care of instead.
Namespace:
ABB.Robotics.Tps.Resources
Assembly:
ABB.Robotics.Tps.Resources (in ABB.Robotics.Tps.Resources.dll) Version: 6.5.129.0
Syntaxpublic static void TraceHandledSystemExceptions(
string obj,
string method,
Exception e
Parameters
- obj
- Type: SystemString
Calling object name. - method
Calling method name. - e
- Type: SystemException
Original exception.
See Also
