DeviceDriverStream Properties |
The DeviceDriverStream type exposes the following members.
| Name | Description | |
| CanRead |
Check if the stream can be read.
(Overrides StreamCanRead.) | |
| CanSeek |
Checks if the stream can be seeked.
(Overrides StreamCanSeek.) | |
| CanTimeout | Gets a value that determines whether the current stream can time out. (Inherited from Stream.) | |
| CanWrite |
Checks if the stream can be written.
(Overrides StreamCanWrite.) | |
| Length |
Not possible to read length from a device stream.
(Overrides StreamLength.) | |
| Position |
It is not possible the seek on a device stream.
(Overrides StreamPosition.) | |
| ReadTimeout | Gets or sets a value, in miliseconds, that determines how long the stream will attempt to read before timing out. (Inherited from Stream.) | |
| WriteTimeout | Gets or sets a value, in miliseconds, that determines how long the stream will attempt to write before timing out. (Inherited from Stream.) |
