TabControl Properties |
The TabControl type exposes the following members.
| Name | Description | |
| AccessibilityObject | Gets the AccessibleObject assigned to the control. (Inherited from Control.) | |
| AccessibleDefaultActionDescription | Gets or sets the default action description of the control for use by accessibility client applications. (Inherited from Control.) | |
| AccessibleDescription | Gets or sets the description of the control used by accessibility client applications. (Inherited from Control.) | |
| AccessibleName | Gets or sets the name of the control used by accessibility client applications. (Inherited from Control.) | |
| AccessibleRole | Gets or sets the accessible role of the control (Inherited from Control.) | |
| ActiveControl | Gets or sets the active control on the container control. (Inherited from ContainerControl.) | |
| AllowDrop | Gets or sets a value indicating whether the control can accept data that the user drags onto it. (Inherited from Control.) | |
| Anchor | Gets or sets the edges of the container to which a control is bound and determines how a control is resized with its parent. (Inherited from Control.) | |
| AutoScaleDimensions | Gets or sets the dimensions that the control was designed to. (Inherited from ContainerControl.) | |
| AutoScaleFactor | Gets the scaling factor between the current and design-time automatic scaling dimensions. (Inherited from ContainerControl.) | |
| AutoScaleMode | Gets or sets the automatic scaling mode of the control. (Inherited from ContainerControl.) | |
| AutoScroll | Gets or sets a value indicating whether the container enables the user to scroll to any controls placed outside of its visible boundaries. (Inherited from ScrollableControl.) | |
| AutoScrollMargin | Gets or sets the size of the auto-scroll margin. (Inherited from ScrollableControl.) | |
| AutoScrollMinSize | Gets or sets the minimum size of the auto-scroll. (Inherited from ScrollableControl.) | |
| AutoScrollOffset | Gets or sets where this control is scrolled to in ScrollControlIntoView(Control). (Inherited from Control.) | |
| AutoScrollPosition | Gets or sets the location of the auto-scroll position. (Inherited from ScrollableControl.) | |
| AutoSize | (Inherited from UserControl.) | |
| AutoSizeMode | Gets or sets how the control will resize itself. (Inherited from UserControl.) | |
| AutoValidate | Gets or sets how the control performs validation when the user changes focus to another control. (Inherited from UserControl.) | |
| BackColor | Gets or sets the background color for the control. (Inherited from Control.) | |
| BackgroundImage | Gets or sets the background image displayed in the control. (Inherited from Control.) | |
| BackgroundImageLayout | Gets or sets the background image layout as defined in the ImageLayout enumeration. (Inherited from Control.) | |
| BindingContext | (Inherited from ContainerControl.) | |
| BorderStyle | Gets or sets the border style of the user control. (Inherited from UserControl.) | |
| Bottom | Gets the distance, in pixels, between the bottom edge of the control and the top edge of its container's client area. (Inherited from Control.) | |
| Bounds | Gets or sets the size and location of the control including its nonclient elements, in pixels, relative to the parent control. (Inherited from Control.) | |
| CanEnableIme | Gets a value indicating whether the ImeMode property can be set to an active value, to enable IME support. (Inherited from ContainerControl.) | |
| CanFocus | Gets a value indicating whether the control can receive focus. (Inherited from Control.) | |
| CanRaiseEvents | Determines if events can be raised on the control. (Inherited from Control.) | |
| CanSelect | Gets a value indicating whether the control can be selected. (Inherited from Control.) | |
| Capture | Gets or sets a value indicating whether the control has captured the mouse. (Inherited from Control.) | |
| CausesValidation | Gets or sets a value indicating whether the control causes validation to be performed on any controls that require validation when it receives focus. (Inherited from Control.) | |
| ClientRectangle | Gets the rectangle that represents the client area of the control. (Inherited from Control.) | |
| ClientSize | Gets or sets the height and width of the client area of the control. (Inherited from Control.) | |
| CompanyName | Gets the name of the company or creator of the application containing the control. (Inherited from Control.) | |
| ContainsFocus | Gets a value indicating whether the control, or one of its child controls, currently has the input focus. (Inherited from Control.) | |
| ContextMenu | Gets or sets the shortcut menu associated with the control. (Inherited from TpsControl.) | |
| ContextMenuStrip | Gets or sets the ContextMenuStrip associated with this control. (Inherited from Control.) | |
| Controls | Gets the collection of controls contained within the control. (Inherited from Control.) | |
| Created | Gets a value indicating whether the control has been created. (Inherited from Control.) | |
| CreateParams | (Inherited from UserControl.) | |
| CurrentAutoScaleDimensions | Gets the current run-time dimensions of the screen. (Inherited from ContainerControl.) | |
| Cursor | Gets or sets the cursor that is displayed when the mouse pointer is over the control. (Inherited from Control.) | |
| DataBindings | Gets the data bindings for the control. (Inherited from Control.) | |
| DefaultCursor | Gets or sets the default cursor for the control. (Inherited from Control.) | |
| DefaultImeMode | Gets the default Input Method Editor (IME) mode supported by the control. (Inherited from Control.) | |
| DefaultMargin | Gets the space, in pixels, that is specified by default between controls. (Inherited from Control.) | |
| DefaultMaximumSize | Gets the length and height, in pixels, that is specified as the default maximum size of a control. (Inherited from Control.) | |
| DefaultMinimumSize | Gets the length and height, in pixels, that is specified as the default minimum size of a control. (Inherited from Control.) | |
| DefaultPadding | Gets the internal spacing, in pixels, of the contents of a control. (Inherited from Control.) | |
| DefaultSize | (Inherited from UserControl.) | |
| DesignMode | Gets a value that indicates whether the Component is currently in design mode. (Inherited from Component.) | |
| DisabledForeColor |
Gets or sets the value of the forecolor used when the control is disabled.
Some controls do not change its visual appearance when disabled. This property has no effect for those controls.
| DisplayRectangle | Gets the rectangle that represents the virtual display area of the control. (Inherited from ScrollableControl.) | |
| Disposing | Gets a value indicating whether the base Control class is in the process of disposing. (Inherited from Control.) | |
| Dock | Gets or sets which control borders are docked to its parent control and determines how a control is resized with its parent. (Inherited from Control.) | |
| DockPadding | Gets the dock padding settings for all edges of the control. (Inherited from ScrollableControl.) | |
| DoubleBuffered | Gets or sets a value indicating whether this control should redraw its surface using a secondary buffer to reduce or prevent flicker. (Inherited from Control.) | |
| Enabled | Gets or sets a value indicating whether the control can respond to user interaction. (Inherited from Control.) | |
| Events | Gets the list of event handlers that are attached to this Component. (Inherited from Component.) | |
| Focused | Gets a value indicating whether the control has input focus. (Inherited from Control.) | |
| Font |
Font for the TabControl
(Overrides TpsControlFont.) | |
| FontHeight | Gets or sets the height of the font of the control. (Inherited from Control.) | |
| FontName | Obsolete.
the FlexPendant.
| ForeColor | Gets or sets the foreground color of the control. (Inherited from Control.) | |
| Handle | Gets the window handle that the control is bound to. (Inherited from Control.) | |
| HasChildren | Gets a value indicating whether the control contains one or more child controls. (Inherited from Control.) | |
| Height | Gets or sets the height of the control. (Inherited from Control.) | |
| HorizontalScroll | Gets the characteristics associated with the horizontal scroll bar. (Inherited from ScrollableControl.) | |
| HScroll | Gets or sets a value indicating whether the horizontal scroll bar is visible. (Inherited from ScrollableControl.) | |
| ImageList | Gets or sets the images to display on the control's tabs. | |
| ImeMode | Gets or sets the Input Method Editor (IME) mode of the control. (Inherited from Control.) | |
| ImeModeBase | Gets or sets the IME mode of a control. (Inherited from Control.) | |
| InvokeRequired | Gets a value indicating whether the caller must call an invoke method when making method calls to the control because the caller is on a different thread than the one the control was created on. (Inherited from Control.) | |
| IsAccessible | Gets or sets a value indicating whether the control is visible to accessibility applications. (Inherited from Control.) | |
| IsDisposed | Gets or sets a value indicating whether the object has already been disposed or not. (Inherited from TpsControl.) | |
| IsEventEnabled |
Gets or sets the status if events shall be processed by the control.
This a property controlled by the derived class but the default behaviour is true in the constructor and false in the Dispose method.
| IsHandleCreated | Gets a value indicating whether the control has a handle associated with it. (Inherited from Control.) | |
| IsMirrored | Gets a value indicating whether the control is mirrored. (Inherited from Control.) | |
| LayoutEngine | Gets a cached instance of the control's layout engine. (Inherited from Control.) | |
| Left | Gets or sets the distance, in pixels, between the left edge of the control and the left edge of its container's client area. (Inherited from Control.) | |
| Location | Gets or sets the coordinates of the upper-left corner of the control relative to the upper-left corner of its container. (Inherited from Control.) | |
| Margin | Gets or sets the space between controls. (Inherited from Control.) | |
| MaximumSize | Gets or sets the size that is the upper limit that GetPreferredSize(Size) can specify. (Inherited from Control.) | |
| MinimumSize | Gets or sets the size that is the lower limit that GetPreferredSize(Size) can specify. (Inherited from Control.) | |
| Name | Gets or sets the name of the control. (Inherited from Control.) | |
| Padding | Gets or sets padding within the control. (Inherited from Control.) | |
| Parent | Gets or sets the parent container of the control. (Inherited from Control.) | |
| ParentForm | Gets the form that the container control is assigned to. (Inherited from ContainerControl.) | |
| PreferredSize | Gets the size of a rectangular area into which the control can fit. (Inherited from Control.) | |
| ProductName | Gets the product name of the assembly containing the control. (Inherited from Control.) | |
| ProductVersion | Gets the version of the assembly containing the control. (Inherited from Control.) | |
| RecreatingHandle | Gets a value indicating whether the control is currently re-creating its handle. (Inherited from Control.) | |
| Region | Gets or sets the window region associated with the control. (Inherited from Control.) | |
| RenderRightToLeft | Obsolete. This property is now obsolete. (Inherited from Control.) | |
| ResizeRedraw | Gets or sets a value indicating whether the control redraws itself when resized. (Inherited from Control.) | |
| Right | Gets the distance, in pixels, between the right edge of the control and the left edge of its container's client area. (Inherited from Control.) | |
| RightToLeft | Gets or sets a value indicating whether control's elements are aligned to support locales using right-to-left fonts. (Inherited from Control.) | |
| ScaleChildren | Gets a value that determines the scaling of child controls. (Inherited from Control.) | |
| SelectedIndex | Gets or sets the index of the currently-selected tab page. | |
| SelectionColor |
Gets or sets the color when an item is selected.
Default color is RGB(0,172,182)
| ShowFocusCues | Gets a value indicating whether the control should display focus rectangles. (Inherited from Control.) | |
| ShowKeyboardCues | Gets a value indicating whether the user interface is in the appropriate state to show or hide keyboard accelerators. (Inherited from Control.) | |
| Site | Gets or sets the site of the control. (Inherited from Control.) | |
| Size | Gets or sets the height and width of the control. (Inherited from Control.) | |
| TabIndex | Gets or sets the tab order of the control within its container. (Inherited from Control.) | |
| TabPages | Gets the collection of tab pages in this tab control. | |
| TabStop | Gets or sets a value indicating whether the user can give the focus to this control using the TAB key. (Inherited from Control.) | |
| Tag | Gets or sets the object that contains data about the control. (Inherited from Control.) | |
| Text | (Inherited from UserControl.) | |
| Top | Gets or sets the distance, in pixels, between the top edge of the control and the top edge of its container's client area. (Inherited from Control.) | |
| TopLevelControl | Gets the parent control that is not parented by another Windows Forms control. Typically, this is the outermost Form that the control is contained in. (Inherited from Control.) | |
| UseWaitCursor | Gets or sets a value indicating whether to use the wait cursor for the current control and all child controls. (Inherited from Control.) | |
| VerticalScroll | Gets the characteristics associated with the vertical scroll bar. (Inherited from ScrollableControl.) | |
| Visible | Gets or sets a value indicating whether the control and all its child controls are displayed. (Inherited from Control.) | |
| VScroll | Gets or sets a value indicating whether the vertical scroll bar is visible. (Inherited from ScrollableControl.) | |
| Width | Gets or sets the width of the control. (Inherited from Control.) | |
| WindowTarget | This property is not relevant for this class. (Inherited from Control.) |
