SDKDisposeBaseDispose Method (Boolean) |
Release managed and native resources of the instance.
Namespace:
ABB.Robotics.Controllers
Assembly:
Syntaxprotected virtual void Dispose(
bool disposing
Parameters
- disposing
- Type: SystemBoolean
true to release both managed and unmanaged resources; false to release only unmanaged resources.
Exceptions
Remarks
This method executes in two distinct scenarios:
- If disposing equals true, the method has been called directly or indirectly by a user's code. Managed and unmanaged resources can be disposed.
- If disposing equals false, the method has been called by the runtime from inside the finalizer and you should not reference other objects. Only unmanaged resources can be disposed.
See Also
