Click or drag to resize
TpsResourceManagerGetString Method (String)
Returns an string associated with an id. First it looks for in the user assembly and then it looks in the global resource assembly.
Namespace:  ABB.Robotics.Tps.Resources
Assembly:  ABB.Robotics.Tps.Resources (in ABB.Robotics.Tps.Resources.dll) Version: 6.5.129.0
Syntax
C#
public override string GetString(
	string name
Parameters
name
Type: SystemString
Name of the resource to search for.
Return Value
Type: String
The value of a resource, if the value is a String. If the string was not found, the requested resource name will be returned.
See Also
