GTPUMasterDialogCancelItem_Click Method |
This method is fired when the Cancel button of the command bar is pressed.
Sets the result to DialogResult.Cancel and closes the control.
Namespace:
Assembly:
ABB.Robotics.GTPU.Windows.Forms (in ABB.Robotics.GTPU.Windows.Forms.dll) Version: 6.5.129.0
Syntaxprotected virtual void CancelItem_Click(
Object sender,
EventArgs e
Parameters
- sender
- Type: SystemObject
Instance of the Cancel button - e
- Type: SystemEventArgs
A EventArgs that contains the event data.
See Also
