Click or drag to resize
YAxis Constructor (Double, Double, DateTime, DateTime, Int32, Int32, Color, Color, Color, Font, Int32, LabelFormat, String, String, Color, Font, AxisType, Boolean)
Initializes a new YAxis instance with specified data.
Namespace:  ABB.Robotics.Tps.Windows.Forms
Assembly:  ABB.Robotics.Tps.Windows.Forms (in ABB.Robotics.Tps.Windows.Forms.dll) Version: 6.5.129.0
Syntax
C#
public YAxis(
	double minValue,
	double maxValue,
	DateTime minDateValue,
	DateTime maxDateValue,
	int minTickCount,
	int maxTickCount,
	Color minTickColor,
	Color maxTickColor,
	Color tickLabelColor,
	Font tickLabelFont,
	int tickLabelPrecision,
	LabelFormat tickLabelFormat,
	string tickDateFormat,
	string label,
	Color labelColor,
	Font labelFont,
	AxisType axisType,
	bool visible
Parameters
minValue
Type: SystemDouble
The minimum value for the axis if autoscale is not applied.
maxValue
Type: SystemDouble
The maximum value for the axis if autoscale is not applied.
minDateValue
Type: SystemDateTime
The minimum date/time value for the axis if autoscale is not applied.
maxDateValue
The maximum date/time value for the axis if autoscale is not applied.
minTickCount
Type: SystemInt32
The number of minor tick marks between each minor tick mark.
maxTickCount
Type: SystemInt32
The number of minor tick marks between each major tick mark.
minTickColor
Type: System.DrawingColor
The color used for minor tick marks.
maxTickColor
The color used for major tick marks.
tickLabelColor
The color used for the axis label.
tickLabelFont
Type: System.DrawingFont
The Font used for the axis label.
tickLabelPrecision
Type: SystemInt32
Number of decimal places displayed by tick labels.
tickLabelFormat
Type: ABB.Robotics.Tps.Windows.FormsLabelFormat
Determines if labels for a chart axis are automatically generated (Default or DateTime) or are provided by the user (Custom).
tickDateFormat
Type: SystemString
String that determines the format of X-axis DateTime tick labels. Standard .Net format strings may be used.
label
Type: SystemString
A label that describes the data type this axis represents.
labelColor
labelFont
axisType
Type: ABB.Robotics.Tps.Windows.FormsAxisType
Determines axis scaling. Choices are Normal, Inverted, and Logarithmic.
visible
Type: SystemBoolean
Determines the visibility of the axis.
See Also
