StorageDeviceCollection Methods |
The StorageDeviceCollection type exposes the following members.
| Name | Description | |
| Clear | Removes all objects from the CollectionBase instance. This method cannot be overridden. (Inherited from CollectionBase.) | |
| Finalize | Allows an object to try to free resources and perform other cleanup operations before it is reclaimed by garbage collection. (Inherited from Object.) | |
| GetEnumerator | Returns an enumerator that iterates through the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnClear | Performs additional custom processes when clearing the contents of the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnClearComplete | Performs additional custom processes after clearing the contents of the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnInsert | Performs additional custom processes before inserting a new element into the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnInsertComplete | Performs additional custom processes after inserting a new element into the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnRemove | Performs additional custom processes when removing an element from the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnRemoveComplete | Performs additional custom processes after removing an element from the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnSet | Performs additional custom processes before setting a value in the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnSetComplete | Performs additional custom processes after setting a value in the CollectionBase instance. (Inherited from CollectionBase.) | |
| OnValidate | Performs additional custom processes when validating a value. (Inherited from CollectionBase.) | |
| RemoveAt | Removes the element at the specified index of the CollectionBase instance. This method is not overridable. (Inherited from CollectionBase.) | |
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
