Click or drag to resize
GroupBox Events
The GroupBox type exposes the following members.
Events
  NameDescription
Public eventAutoSizeChanged
Occurs when the value of the AutoSize property has changed.
(Inherited from Panel.)
Public eventBackColorChanged
Occurs when the value of the BackColor property changes.
(Inherited from Control.)
Public eventBackgroundImageChanged
Occurs when the value of the BackgroundImage property changes.
Public eventBackgroundImageLayoutChanged
Occurs when the BackgroundImageLayout property changes.
Public eventBindingContextChanged
Occurs when the value of the BindingContext property changes.
Public eventCausesValidationChanged
Occurs when the value of the CausesValidation property changes.
Public eventChangeUICues
Occurs when the focus or keyboard user interface (UI) cues change.
Public eventClick
Occurs when the control is clicked.
Public eventClientSizeChanged
Occurs when the value of the ClientSize property changes.
Public eventContextMenuChanged
Occurs when the value of the ContextMenu property changes.
Public eventContextMenuStripChanged
Occurs when the value of the ContextMenuStrip property changes.
Public eventControlAdded (Inherited from Control.)
Public eventControlRemoved (Inherited from Control.)
Public eventCursorChanged
Occurs when the value of the Cursor property changes.
Public eventDisposed
Occurs when the component is disposed by a call to the Dispose method.
(Inherited from Component.)
Public eventDockChanged
Occurs when the value of the Dock property changes.
Public eventDoubleClick
Occurs when the control is double-clicked.
Public eventDragDrop
Occurs when a drag-and-drop operation is completed.
Public eventDragEnter
Occurs when an object is dragged into the control's bounds.
Public eventDragLeave
Occurs when an object is dragged out of the control's bounds.
Public eventDragOver
Occurs when an object is dragged over the control's bounds.
Public eventEnabledChanged
Occurs when the Enabled property value has changed.
Public eventEnter
Occurs when the control is entered.
Public eventFontChanged
Occurs when the Font property value changes.
Public eventForeColorChanged
Occurs when the ForeColor property value changes.
Public eventGiveFeedback
Occurs during a drag operation.
Public eventGotFocus
Occurs when the control receives focus.
Public eventHandleCreated
Occurs when a handle is created for the control.
Public eventHandleDestroyed
Occurs when the control's handle is in the process of being destroyed.
Public eventHelpRequested
Occurs when the user requests help for a control.
Public eventImeModeChanged
Occurs when the ImeMode property has changed.
Public eventInvalidated
Occurs when a control's display requires redrawing.
Public eventKeyDown
This member is not meaningful for this control.
Public eventKeyPress
Public eventKeyUp
Public eventLayout
Occurs when a control should reposition its child controls.
Public eventLeave
Occurs when the input focus leaves the control.
Public eventLocationChanged
Occurs when the Location property value has changed.
Public eventLostFocus
Occurs when the control loses focus.
Public eventMarginChanged
Occurs when the control's margin changes.
Public eventMouseCaptureChanged
Occurs when the control loses mouse capture.
Public eventMouseClick
Occurs when the control is clicked by the mouse.
Public eventMouseDoubleClick
Occurs when the control is double clicked by the mouse.
Public eventMouseDown
Occurs when the mouse pointer is over the control and a mouse button is pressed.
Public eventMouseEnter
Occurs when the mouse pointer enters the control.
Public eventMouseHover
Occurs when the mouse pointer rests on the control.
Public eventMouseLeave
Occurs when the mouse pointer leaves the control.
Public eventMouseMove
Occurs when the mouse pointer is moved over the control.
Public eventMouseUp
Occurs when the mouse pointer is over the control and a mouse button is released.
Public eventMouseWheel
Occurs when the mouse wheel moves while the control has focus.
Public eventMove
Occurs when the control is moved.
Public eventPaddingChanged
Occurs when the control's padding changes.
Public eventPaint
Occurs when the control is redrawn.
Public eventParentChanged
Occurs when the Parent property value changes.
Public eventPreviewKeyDown
Occurs before the KeyDown event when a key is pressed while focus is on this control.
Public eventQueryAccessibilityHelp
Occurs when AccessibleObject is providing help to accessibility applications.
Public eventQueryContinueDrag
Occurs during a drag-and-drop operation and enables the drag source to determine whether the drag-and-drop operation should be canceled.
Public eventRegionChanged
Occurs when the value of the Region property changes.
Public eventResize
Occurs when the control is resized.
Public eventRightToLeftChanged
Occurs when the RightToLeft property value changes.
Public eventScroll
Occurs when the user or code scrolls through the client area.
(Inherited from ScrollableControl.)
Public eventSizeChanged
Occurs when the Size property value changes.
Public eventStyleChanged
Occurs when the control style changes.
Public eventSystemColorsChanged
Occurs when the system colors change.
Public eventTabIndexChanged
Occurs when the TabIndex property value changes.
Public eventTabStopChanged
Occurs when the TabStop property value changes.
Public eventTextChanged
Public eventValidated
Occurs when the control is finished validating.
Public eventValidating
Occurs when the control is validating.
Public eventVisibleChanged
Occurs when the Visible property value changes.
Top
See Also
