TpsResourceManager Properties |
The TpsResourceManager type exposes the following members.
| Name | Description | |
| BaseName | Gets the root name of the resource files that the ResourceManager searches for resources. (Inherited from ResourceManager.) | |
| FallbackLocation | Gets or sets the location from which to retrieve neutral fallback resources. (Inherited from ResourceManager.) | |
| IgnoreCase | Gets or sets a Boolean value indicating whether the current instance of ResourceManager allows case-insensitive resource lookups in the GetString(String) and GetObject(String) methods. (Inherited from ResourceManager.) | |
| ResourceSetType | (Inherited from ResourceManager.) |
