Click or drag to resize
ListViewSubItem Methods
The ListViewSubItem type exposes the following members.
Methods
  NameDescription
Public methodCreateObjRef
Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object.
(Inherited from MarshalByRefObject.)
Public methodDispose
Releases all resources used by the Component.
(Inherited from Component.)
Protected methodDispose(Boolean)
Releases the unmanaged resources used by the Component and optionally releases the managed resources.
Public methodEquals
Determines whether the specified Object is equal to the current Object.
(Inherited from Object.)
Protected methodFinalize
Releases unmanaged resources and performs other cleanup operations before the Component is reclaimed by garbage collection.
Public methodGetHashCode
Serves as a hash function for a particular type.
Public methodGetLifetimeService
Retrieves the current lifetime service object that controls the lifetime policy for this instance.
Protected methodGetService
Returns an object that represents a service provided by the Component or by its Container.
Public methodGetType
Gets the type of the current instance.
Public methodInitializeLifetimeService
Obtains a lifetime service object to control the lifetime policy for this instance.
Protected methodMemberwiseClone
Creates a shallow copy of the current Object.
Protected methodMemberwiseClone(Boolean)
Creates a shallow copy of the current MarshalByRefObject object.
Public methodToString
Returns a String containing the name of the Component, if any. This method should not be overridden.
Top
See Also
