Click or drag to resize
MenuItemChecked Property
Gets or sets a value indicating whether a check mark appears next to the text of the menu item.
Namespace:  ABB.Robotics.Tps.Windows.Forms
Assembly:  ABB.Robotics.Tps.Windows.Forms (in ABB.Robotics.Tps.Windows.Forms.dll) Version: 6.5.129.0
Syntax
C#
public bool Checked { get; set; }
Property Value
Type: Boolean
true if the menu item to place a check mark next to the menu item; otherwise, false. The default is false.
See Also
