How to obtain and install a license key for RAB 5.09 or earlier |
In RAB 5.10, the license check was removed from the software, which allowed anyone to use Robot Application Builder for free. This means you no longer need to bother about getting a license, or including a licx file in your PC application.
For RAB version 5.09 or earlier, licensing is the second part of the installation procedure. In case you need to develop a RAB application for RobotWare 5.09 or earlier you need to turn to support to get a free license key. |
Follow these steps when you have received the e-mail with the license key file:
Step | Action |
1 | Detach the license key file from the e-mail and save it to a folder on your PC. |
2 | Double-click the license key file. This opens the License Install Wizard . |
3 | Follow the instructions in the wizard. |
To execute FlexPendant SDK applications towards a real robot controller you must connect your PC to the robot controller, either through the network or directly to the service port on the controller. For detailed information, see How to set up your PC to communicate with robot. |
