SystemInfoSystemOptions Property |
Returns the installed system options of the active system.
Namespace:
ABB.Robotics.Controllers.SystemInfoDomain
Assembly:
Syntaxpublic static SystemOption[] SystemOptions { get; }Property Value
Type:
SystemOption
Exceptions
Examples
This example shows the system options of the current robot system in a listview.
The system option names are displayed in the first column and the sub options (if any) in the second column.
private void ShowOptions()
try
ABB.Robotics.Controllers.SystemInfoDomain.SystemOption[] sysOptions = null;
sysOptions = ABB.Robotics.Controllers.SystemInfoDomain.SystemInfo.SystemOptions;
if (sysOptions != null)
for (int i = 0; i < sysOptions.Length; i++)
ListViewItem item;
item = new ListViewItem(sysOptions[i].Name);
listView1.Items.Add(item);
ABB.Robotics.Controllers.SystemInfoDomain.SystemOption[] subOptions = null;
subOptions = sysOptions[i].SubOptions;
if (subOptions != null)
StringBuilder sb = new StringBuilder();
for (int j = 0; j < subOptions.Length; j++)
sb.Append(subOptions[j].Name);
sb.Append(", ");
item.SubItems.Add(sb.ToString());
catch (GeneralException ee)
catch (System.Exception ee)
See Also
