Click or drag to resize
TpsResourceManagerGetImage Method
Returns an image associated with a fileName.
Namespace:  ABB.Robotics.Tps.Resources
Assembly:  ABB.Robotics.Tps.Resources (in ABB.Robotics.Tps.Resources.dll) Version: 6.5.129.0
Syntax
C#
public Image GetImage(
	string fileName
Parameters
fileName
Type: SystemString
Name of the image file to be loaded
Return Value
Type: Image
An Image associated with the fileName. If the file was not found, then it searches for a resource associated with the fileName. If this is not found either, the method returns null.
NOTE: The image files must be located in the Application path.
Remarks
First it looks if there is an image file from where it can load the requested image. If not it looks for an Image associated with the requested id.
See Also
