MainMenu Properties |
The MainMenu type exposes the following members.
| Name | Description | |
| CanRaiseEvents | Gets a value indicating whether the component can raise an event. (Inherited from Component.) | |
| DesignMode | Gets a value that indicates whether the Component is currently in design mode. (Inherited from Component.) | |
| Events | Gets the list of event handlers that are attached to this Component. (Inherited from Component.) | |
| IsParent | Gets a value indicating whether this menu contains any menu items. (Inherited from Menu.) | |
| MenuItems | Gets a value indicating the collection of MenuItem objects associated with the menu. (Inherited from Menu.) | |
| Site | (Inherited from Component.) |
