XAxis Constructor (Double, Double, DateTime, DateTime, Int32, Int32, Color, Color, Color, Font, Int32, LabelFormat, String, String, Color, Font, AxisType, Boolean, Boolean) |
Initializes a new XAxis instance with the specified data.
Namespace:
Assembly:
Syntaxpublic XAxis(
double minValue,
double maxValue,
DateTime minDateValue,
DateTime maxDateValue,
int minTickCount,
int majTickCount,
Color minTickColor,
Color majTickColor,
Color tickLabelColor,
Font tickLabelFont,
int tickLabelPrecision,
LabelFormat tickLabelFormat,
string tickDateFormat,
string label,
Color labelColor,
Font labelFont,
AxisType axisType,
bool visible,
bool tickCenterLabels
Parameters
- minValue
- Type: SystemDouble
The minimum value for the axis if autoscale is not applied. - maxValue
The maximum value for the axis if autoscale is not applied. - minDateValue
- Type: SystemDateTime
The minimum date/time value for the axis if autoscale is not applied. - maxDateValue
The maximum date/time value for the axis if autoscale is not applied. - minTickCount
- Type: SystemInt32
The number of minor tick marks between each minor tick mark. - majTickCount
- Type: SystemInt32
The number of minor tick marks between each major tick mark. - minTickColor
- Type: System.DrawingColor
The color used for minor tick marks. - majTickColor
The color used for major tick marks. - tickLabelColor
The color used for the axis label. - tickLabelFont
- Type: System.DrawingFont
The Font used for the axis label. - tickLabelPrecision
- Type: SystemInt32
Number of decimal places displayed by tick labels. - tickLabelFormat
- Type: ABB.Robotics.Tps.Windows.FormsLabelFormat
Determines if labels for a chart axis are automatically generated (Default or DateTime) or are provided by the user (Custom). - tickDateFormat
- Type: SystemString
String that determines the format of X-axis DateTime tick labels. Standard .Net format strings may be used. - label
A label that describes the data type this axis represents. - labelColor
The color used for the axis label. - labelFont
The Font used for the axis label. - axisType
- Type: ABB.Robotics.Tps.Windows.FormsAxisType
Determines axis scaling. Choices are Normal, Inverted, and Logarithmic. - visible
- Type: SystemBoolean
Determines the visibility of the axis. - tickCenterLabels
If true, tick labels will be centered between major ticks rather than on major ticks. Primarily used for bar charts.
See Also
