Click or drag to resize
TpsResourceManager Constructor (String, Assembly)
Initializes a new instance of the TpsResourceManager class that looks up resources contained in files derived from the specified root name using the given Assembly.
Namespace:  ABB.Robotics.Tps.Resources
Assembly:  ABB.Robotics.Tps.Resources (in ABB.Robotics.Tps.Resources.dll) Version: 6.5.129.0
Syntax
C#
public TpsResourceManager(
	string baseName,
	Assembly assembly
Parameters
baseName
Type: SystemString
The root name of the resources. For example, the root name for the resource file named "MyResource.en-US.resources" is "MyResource".
assembly
Type: System.ReflectionAssembly
The main Assembly for the resources.
Remarks
If a resource is not found in the specified assembly, it will be look inside the predefined resource of the FlexPendant system.
See Also
