FlexPendant Developer Support
FlexPendant Development
References
ABB.Robotics.Controllers.ConfigurationDomain
Instance Class
Instance Methods
Delete Method
GetAttribute Method
GetAttributes Method
GetIsInternal Method
GetName Method
GetUrl Method
GetValue Method
SetValue Method
Instance
GetValue Method
Gets the value of an attribute of this instance.
Namespace:
Assembly:
Syntax
C#
Copy
public
string
GetValue
string
name
Parameters
name
Type:
System
String
The name of the attribute.
Return Value
Type:
String
The value of the attribute.
Exceptions
Exception
Condition
ArgumentException
The named attribute is not found.
See Also
Reference
Instance Class
ABB.Robotics.Controllers.ConfigurationDomain Namespace
FlexPendant Developer Center | This content is licensed. For details and restrictions, see the
Content License
