ListBoxItem Methods |
The ListBoxItem type exposes the following members.
| Name | Description | |
| CreateObjRef | Creates an object that contains all the relevant information required to generate a proxy used to communicate with a remote object. (Inherited from MarshalByRefObject.) | |
| Dispose | Releases all resources used by the Component. (Inherited from Component.) | |
| Dispose(Boolean) | Releases the unmanaged resources used by the Component and optionally releases the managed resources. (Inherited from Component.) | |
| Finalize | Releases unmanaged resources and performs other cleanup operations before the Component is reclaimed by garbage collection. (Inherited from Component.) | |
| GetLifetimeService | Retrieves the current lifetime service object that controls the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| GetService | (Inherited from Component.) | |
| InitializeLifetimeService | Obtains a lifetime service object to control the lifetime policy for this instance. (Inherited from MarshalByRefObject.) | |
| MemberwiseClone(Boolean) | Creates a shallow copy of the current MarshalByRefObject object. (Inherited from MarshalByRefObject.) | |
| ToString |
Returns a String that represents the current Object.
(Overrides ComponentToString.) |
