SignalCollection Methods |
The SignalCollection type exposes the following members.
| Name | Description | |
| Clear | Removes all objects from the CollectionBase instance. This method cannot be overridden. (Inherited from CollectionBase.) | |
| GetEnumerator | Returns an enumerator that iterates through the CollectionBase instance. (Inherited from CollectionBase.) | |
| RemoveAt | Removes the element at the specified index of the CollectionBase instance. This method is not overridable. (Inherited from CollectionBase.) | |
| ToString | Returns a string that represents the current object. (Inherited from Object.) |
