FlexPendant Developer Support
FlexPendant Development
References
ListView.ListViewItemCollection Class
ListViewItemCollection Methods
Add Method
Contains Method
IndexOf Method
Insert Method
OnClear Method
OnClearComplete Method
OnInsertComplete Method
OnRemoveComplete Method
Remove Method
ListView
Contains Method
Determines if the specified
ListViewItem
is a member of the collection.
Namespace:
Assembly:
Syntax
C#
Copy
public
virtual
bool
Contains
ListViewItem
item
Parameters
item
Type:
ListViewItem
The
ListViewItem
to locate in the collection.
Return Value
Type:
Boolean
true
if the
ListViewItem
is a member of the collection; otherwise,
false
See Also
Reference
ListView
ABB.Robotics.Tps.Windows.Forms Namespace
FlexPendant Developer Center | This content is licensed. For details and restrictions, see the
Content License
